Hi All
I just set up intrusion audio alerts to speek a message whenever one of my doors are opened when away mode.
The thing is that the speech is too fast in my oppinion.
Is there any way to slow down the tempo of the speech?
Kasper
Hi All
Kasper
It kind of depends on what you are using for TTS. If you are using the built-in speech synthesis, you can use Amazon Polly tags, specifically the prosody tag, to change the speed.
https://docs.aws.amazon.com/polly/latest/dg/supportedtags.html#prosody-tag
Example: "For dramatic purposes, you might wish to <prosody rate="slow">slow up the speaking rate of your text.</prosody>"
