I can't find the solution to a rule that says if a door or window is open when I connect an alarm, I get a message. I can't put it together in rule machine.
Check HSM Setting for the section about setting up notifications for alerts for Arming Failures. I think that is whay you are looking for.
Of course the answer was in there. Thanks
