Hello there.
Like modes can interact between two hubs, will that also be possible with hsm, meaning, when hsm on hub1 arms, hub two2 should also arm, or do I have two fiddle around with virtual switches.
Thanks from Denmark
Hello there.
Thanks from Denmark
Hub mesh is your friend. I have HSM on only one hub, but it uses the devices from the second hub also. You don't need to run HSM on both hubs.
Like @StephenH said most people will only run HSM on one hub and use Hub Mesh to share the devices; however, if you do want/need to use HSM in this manner or with hubs that aren't on the same LAN:
It just came up because..... it the way it is
I wil move my hsm to one hub only. Thanks
Well if you change your mind and need help setting it up, you know where to find me.
