Version 2.1.0 (312) HSM status is not updating on the homepage. It does show armed inside the app but disarmed on the home page. Mode is correct.
@moncho1138 Just making sure you know.
What's the app build and hub build that you have?
App 2.1.0 (312) Hub 2.4.0.151
@moncho1138 I am having the same issue of HSM not updating on the home screen on the android app since it was released yesterday, however mine shows armed home regardless of actual status. It is disarmed. Attached is screenshots of what I am seeing along with my app level and hub level.
Edit: I also have noticed when I am on my local network at home it should always say Living Room Hub (Local) but it will sometimes say Living Room Hub (Cloud) as if I am away from home. When home my phone is always on my wifi as I don't have cell service here. When I am home and click on the Living Room Hub (Cloud) the next screen is as it should be when I am home with my local options such as connect to hub not remote admin.
I can confirm this bug, it will be fixed on the next beta/release, but once Hub 2.4.1 is released to public it will work with current app version, whatever comes first.
As always thank you so much for your quick response and quick actions.
Does the update cover both the HSM issues and local vs cloud issues being shown?
For the cloud/local part, we have some improvements in mind that will help on avoiding that, but since Cloud/Local detection depends on many factors we can't tell for sure if that will work.
I understand. Mine worked perfectly up until the app update to the latest version. There was no changes on my network. I am sure that doesn't help you not knowing my specifics but thought I would offer that up.
Honestly, the HSM issues is the biggest I encountered because I can't quickly see the status. The local/cloud issues honestly is just a visual because the next screen is correct for my location. I get the correct screen if I am home and get the opposite screen when I am away from home.
Android beta App 2.1.0 (312) Hub 2.4.0.151. Also just found an auto off virtual switch set at 500ms never turns off on the app. It flickers but stays green, however I can see it is working by watching the device in a browser. Not a big deal but I know it used to work.
