Hi team!
I am running a C-7 with FW version 2.3.7.145. I have HSM properly configured and when an alarm is triggered, events does not seem to propagate to webcore.
This is the event that I see on the Hubitat log:
However the event does not show-up in Webcore:
What am I missing here?
Make sure you are running latest webCoRE is using user install.
if using built-in webCoRe, you should update your habitat firmware to get latest webCoRE
Thanks! I am using bulit-in webCore and issue was solved after I upgraded hub FW to 2.3.8.119.
