HSM fail to update by mode change
I am using a rule in rule machine so when I change the mode the HSM will update following the mode as next:
Then I change the mode to away and check the logs and looks to be triggering as expected:
but the HSM is actually NOT changed to "Arm Away" it just stays at "All disarmed":
Am I doing something wrong? any suggestion to fix it?
