Did anyone in this thread ever get any resolution or reply?
Not that I know of. It still happens to me randomly. I have tried to find the issue but no resolve yet. Everytime it happens it continues to happen until I restart hubitat. Then it works fine for a while until it doesn't.
So this just happened coming home today. Alarm should disarm when front door is unlock by my code or wifes code. (Works most of the time, except when it this glitch happens.
Log:
dev:32019-11-11 09:31:29.368 am info Keypad was disarmed [digital]
dev:32019-11-11 09:31:21.998 am info Keypad was disarmed [digital]
dev:32019-11-11 09:31:05.416 am info Keypad is inactive
dev:32019-11-11 09:30:48.103 am info Keypad was disarmed [digital]
dev:32019-11-11 09:30:41.780 am info Keypad was disarmed [digital]
dev:32019-11-11 09:30:34.962 am info Keypad was disarmed [digital]
dev:32019-11-11 09:30:31.143 am info Keypad is active
dev:32019-11-11 09:30:27.747 am info Keypad was disarmed [digital]
dev:32019-11-11 09:30:15.331 am info Keypad is inactive
dev:32019-11-11 09:30:00.937 am info Keypad temperature is 71.79°F
dev:32019-11-11 09:29:51.660 am info Keypad was disarmed [digital]
dev:1052019-11-11 09:29:49.398 am debug Valve is open
dev:472019-11-11 09:29:49.264 am info Porch Door was closed
app:882019-11-11 09:29:48.510 am info Keypad Beep - When Something Opened Triggered
app:882019-11-11 09:29:47.947 am info Keypad Beep - When Something Opened: Porch Door contact open
dev:472019-11-11 09:29:46.546 am info Porch Door was opened
dev:32019-11-11 09:29:45.290 am info Keypad is active
dev:722019-11-11 09:29:45.049 am info Front Outside Light is off [physical]
dev:722019-11-11 09:29:44.733 am info Front Outside Light is off [physical]
dev:532019-11-11 09:29:44.421 am info Outside Temp is active
dev:472019-11-11 09:29:44.335 am info Porch Door was closed
dev:32019-11-11 09:29:43.560 am info Keypad was disarmed [digital]
dev:722019-11-11 09:29:39.863 am info Front Outside Light is off [physical]
dev:722019-11-11 09:29:39.681 am info Front Outside Light is off [physical]
dev:32019-11-11 09:29:39.439 am info Keypad is inactive
dev:722019-11-11 09:29:39.390 am info Front Outside Light is off [physical]
dev:722019-11-11 09:29:39.186 am info Front Outside Light is off [physical]
dev:722019-11-11 09:29:38.800 am info Front Outside Light is off [physical]
dev:722019-11-11 09:29:37.727 am info Front Outside Light is off [physical]
dev:722019-11-11 09:29:37.715 am info Front Outside Light is off [physical]
app:1302019-11-11 09:29:37.289 am info Alarm Off Triggered
dev:1722019-11-11 09:29:35.752 am info V - Alarm_ON was turned off
app:762019-11-11 09:29:35.502 am info Alarm Triggered - Intruder: Home hsmAlert cancel
app:1292019-11-11 09:29:35.371 am info Alarm Arming: Home hsmStatus disarmed
app:1302019-11-11 09:29:35.303 am info Alarm Off: Home hsmStatus disarmed
app:762019-11-11 09:29:35.100 am info Alarm Triggered - Intruder: Home hsmAlert cancel
dev:722019-11-11 09:29:34.963 am info Front Outside Light is off [physical]
dev:722019-11-11 09:29:34.850 am info Front Outside Light is off [physical]
app:762019-11-11 09:29:34.532 am info Alarm Triggered - Intruder: Home hsmAlert cancel
app:762019-11-11 09:29:34.426 am info Alarm Triggered - Intruder: Home hsmAlert cancel
app:762019-11-11 09:29:33.926 am info Alarm Triggered - Intruder: Home hsmAlert cancel
dev:722019-11-11 09:29:33.906 am info Front Outside Light is off [digital]
app:762019-11-11 09:29:33.315 am info Alarm Triggered - Intruder: Home hsmAlert cancel
app:92019-11-11 09:29:32.099 am warn Alert Intrusion canceled
app:92019-11-11 09:29:31.794 am info Disarmed
app:92019-11-11 09:29:31.482 am warn Alert Intrusion canceled
app:92019-11-11 09:29:31.463 am warn Alert Intrusion canceled
app:92019-11-11 09:29:31.390 am warn Alert Intrusion canceled
app:92019-11-11 09:29:31.281 am warn Alert Intrusion canceled
app:92019-11-11 09:29:30.874 am warn Alert Intrusion canceled
dev:722019-11-11 09:29:29.688 am info Front Outside Light is off [physical]
dev:32019-11-11 09:29:29.048 am info Keypad alarm was turned off
dev:32019-11-11 09:29:28.470 am info Keypad alarm was turned off
dev:32019-11-11 09:29:28.427 am info Keypad alarm was turned off
dev:32019-11-11 09:29:28.358 am info Keypad alarm was turned off
dev:32019-11-11 09:29:28.350 am info Keypad alarm was turned off
dev:32019-11-11 09:29:27.349 am info Keypad alarm was turned off
dev:722019-11-11 09:29:23.197 am info Front Outside Light is off [physical]
dev:1612019-11-11 09:29:19.956 am info Hallway Siren: alarm is off
dev:1612019-11-11 09:29:19.666 am info Hallway Siren: alarm is off
dev:722019-11-11 09:29:18.558 am info Front Outside Light is off [physical]
dev:722019-11-11 09:29:17.804 am info Front Outside Light is off [digital]
app:1292019-11-11 09:29:15.611 am info Alarm Arming: Home hsmStatus allDisarmed
app:1302019-11-11 09:29:15.259 am info Alarm Off: Home hsmStatus allDisarmed
app:762019-11-11 09:29:14.744 am info Alarm Triggered - Intruder: Home hsmAlert cancel
app:92019-11-11 09:29:13.640 am info All Disarmed
app:92019-11-11 09:29:13.569 am warn Alert Intrusion canceled
dev:32019-11-11 09:29:12.955 am info Keypad alarm was turned off
dev:32019-11-11 09:29:12.280 am info Keypad tamper is clear
dev:32019-11-11 09:29:10.141 am info Keypad battery is 100%
dev:32019-11-11 09:29:09.365 am info Keypad is active
dev:32019-11-11 09:29:09.205 am info Keypad is active
dev:1612019-11-11 09:28:48.518 am info Hallway Siren: alarm is both
app:762019-11-11 09:28:48.387 am info Alarm Triggered - Intruder Triggered
dev:1672019-11-11 09:28:47.309 am info Sending Message: [ Intruder Alert ] Priority: [0] to [All Devices]
app:762019-11-11 09:28:46.936 am info Alarm Triggered - Intruder: Home hsmAlert intrusion
dev:722019-11-11 09:28:46.056 am info Front Outside Light was set to flash with a rate of 750 milliseconds
app:882019-11-11 09:28:44.746 am info Keypad Beep - When Something Opened Triggered
dev:32019-11-11 09:28:44.466 am info Keypad alarm set to siren
app:92019-11-11 09:28:44.131 am warn Alert Intrusion Porch Door open
app:882019-11-11 09:28:44.121 am info Keypad Beep - When Something Opened: Porch Door contact open
dev:472019-11-11 09:28:43.209 am info Porch Door was opened
dev:32019-11-11 09:28:42.129 am info Keypad is inactive
dev:722019-11-11 09:28:40.971 am info Front Outside Light is off [physical]
app:1302019-11-11 09:28:40.421 am info Alarm Off Triggered
dev:1722019-11-11 09:28:39.618 am info V - Alarm_ON was turned off
app:1302019-11-11 09:28:39.413 am info Alarm Off: Home hsmStatus disarmed
app:1292019-11-11 09:28:39.309 am info Alarm Arming: Home hsmStatus disarmed
app:762019-11-11 09:28:39.117 am info Alarm Triggered - Intruder: Home hsmAlert cancel
dev:722019-11-11 09:28:38.880 am info Front Outside Light is off [physical]
dev:722019-11-11 09:28:38.669 am info Front Outside Light is off [digital]
app:92019-11-11 09:28:37.725 am info Disarmed
app:92019-11-11 09:28:37.675 am warn Alert Intrusion canceled
dev:722019-11-11 09:28:37.352 am info Front Outside Light is off [physical]
dev:32019-11-11 09:28:36.877 am info Keypad alarm was turned off
dev:1622019-11-11 09:28:36.511 am info Garage Siren: alarm is off
dev:1612019-11-11 09:28:35.186 am info Hallway Siren: alarm is off
dev:722019-11-11 09:28:35.082 am info Front Outside Light is off [physical]
dev:722019-11-11 09:28:34.969 am info Front Outside Light is off [physical]
dev:722019-11-11 09:28:34.724 am info Front Outside Light is off [digital]
app:1302019-11-11 09:28:33.226 am info Alarm Off: Home hsmStatus allDisarmed
app:1292019-11-11 09:28:33.037 am info Alarm Arming: Home hsmStatus allDisarmed
app:762019-11-11 09:28:33.033 am info Alarm Triggered - Intruder: Home hsmAlert cancel
app:92019-11-11 09:28:31.817 am info All Disarmed
app:92019-11-11 09:28:31.746 am warn Alert Intrusion canceled
dev:32019-11-11 09:28:31.096 am info Keypad alarm was turned off
dev:32019-11-11 09:28:13.931 am info Keypad battery is 100%
dev:32019-11-11 09:28:13.878 am info Keypad tamper is clear
dev:32019-11-11 09:28:12.137 am info Keypad is active
dev:32019-11-11 09:28:11.951 am info Keypad is active
dev:32019-11-11 09:28:11.124 am info Keypad was disarmed [digital]
app:762019-11-11 09:27:55.516 am info Alarm Triggered - Intruder Triggered
dev:472019-11-11 09:27:54.816 am info Porch Door was closed
dev:1672019-11-11 09:27:54.658 am info Sending Message: [ Intruder Alert ] Priority: [0] to [All Devices]
app:762019-11-11 09:27:54.465 am info Alarm Triggered - Intruder: Home hsmAlert intrusion
dev:722019-11-11 09:27:53.761 am info Front Outside Light was set to flash with a rate of 750 milliseconds
dev:32019-11-11 09:27:53.133 am info Keypad battery is 100%
dev:32019-11-11 09:27:53.103 am info Keypad tamper is clear
app:882019-11-11 09:27:52.495 am info Keypad Beep - When Something Opened Triggered
app:882019-11-11 09:27:52.079 am info Keypad Beep - When Something Opened: Porch Door contact open
app:92019-11-11 09:27:52.011 am warn Alert Intrusion Porch Door open
dev:472019-11-11 09:27:51.387 am info Porch Door was opened
dev:1622019-11-11 09:27:41.510 am info Garage Siren: alarm is both
dev:1612019-11-11 09:27:40.483 am info Hallway Siren: alarm is both
dev:1122019-11-11 09:27:39.839 am info Living Room Light was set to 99% [digital]
dev:1122019-11-11 09:27:39.824 am info Living Room Light was turned on [digital]
dev:712019-11-11 09:27:39.302 am info Dining Table Light was set to 99% [digital]
app:762019-11-11 09:27:38.634 am info Alarm Triggered - Intruder Triggered
dev:1672019-11-11 09:27:37.639 am info Sending Message: [ Intruder Alert ] Priority: [0] to [All Devices]
app:762019-11-11 09:27:37.419 am info Alarm Triggered - Intruder: Home hsmAlert intrusion
dev:722019-11-11 09:27:36.795 am info Front Outside Light was set to flash with a rate of 750 milliseconds
dev:32019-11-11 09:27:35.254 am info Keypad alarm set to siren
app:92019-11-11 09:27:35.133 am warn Alert Intrusion Front Door open
dev:1172019-11-11 09:27:23.026 am info Front Door Lock was locked by thumb turn [physical]
app:762019-11-11 09:27:20.702 am info Alarm Triggered - Intruder: Home hsmAlert intrusion-delay
app:882019-11-11 09:27:20.470 am info Keypad Beep - When Something Opened Triggered
app:92019-11-11 09:27:19.940 am warn Alert Intrusion pending Front Door open
app:882019-11-11 09:27:19.806 am info Keypad Beep - When Something Opened: Front Door contact open
app:1302019-11-11 09:27:19.413 am info Alarm Off Triggered
dev:392019-11-11 09:27:18.559 am info Front Door was opened
app:1302019-11-11 09:27:18.248 am info Alarm Off: Home hsmStatus disarmed
app:1292019-11-11 09:27:18.142 am info Alarm Arming: Home hsmStatus disarmed
dev:32019-11-11 09:27:17.624 am trace sendArmResponse- sucess, bin:1, armMode:03 -> armRequest:00, exitDelay:0, isInitiator:false, lcData:[isValid:true, isInitiator:false, code:0000, name:not required, codeNumber:-1]
app:92019-11-11 09:27:17.420 am info Disarmed
app:1682019-11-11 09:27:16.795 am info Disarm Alarm On front Door Keypad Triggered
app:1682019-11-11 09:27:16.436 am info Disarm Alarm On front Door Keypad: Front Door Lock lockCode Albert
dev:1172019-11-11 09:27:15.656 am info Front Door Lock was unlocked by Albert
I know it isn't a "clean" solution, but why not reboot the hub automatically once a day or every couple of days?
I have seen that multiple issues are solved by reboot. Pretty simple to implement.
A few days after I posted that I get the hub to reboot daily and not had the issue since.
