Hi,
Recently purchased Hubitat and wanted to set up the HSM but I have hit a dead end.
I am using Aeotec Multipurpose Sensor (Contact + Vibration/Acceleration).
It links up like a charm and both type of sensors show up.
When working in HSM, the door contact can be set up without issue. However, the vibration is a problem.
If I set up HSB Custom, the device changes between Acceleration/Vibration inconsistently.
Now the issue, if I select HSM Night Mode only, then HSM will not send a notification! Only when I select all modes (home, away, evening and night) will the device send a notification. Why is this??
And why does system show Entrance.Door.Vibration Armed as RESTRICTED?
Please see pictures below for my settings. Appreciate any help I can get.
Sensor data:
HSM Setup
HSM Rule - RESTRICTED (!)
