You can't enable/disable an Alexa routine from HE but if you used virtual devices to report open and close to Alexa you could stop those HE devices from reporting changes.
If you are using HE to send the announcements to Alexa that is easier to control, but if a Alexa routine is making the announcement it changes how you might approach this. I am sure what you want can be accomplished but it depends on how you have HSM and these contacts setup. A specific example of your current setup would be helpful.
Thanks for responding - below is my logic for arming/disarming hsm
i created a virtual switch called security system
when that switch is turned on, hsm will arm-away, when it turns off hsm will disarm.
my door sensors are connected to hsm and also exposed to alexa (with routines)
my thinking going into this was that if hsm were disarmed the door/window sensors would be disabled and not report changes/trigger the alexa routines but what i'm finding is that they still do.
even when hsm is disarmed the alexa routines continue to trigger.
i suppose i could create virtual devices for each sensor and rule for each one to only trigger when hsm is armed but that seems a bit over developed, maybe there is a simpler way?
No need to expose anything but the virtual switch to alexa. The reason is alexa will keep notifying you of windows and doors opening if you expose them... The sensors won't be disabled.
