HSM Configure Intrusion Audio Alerts
Hi bravenel
I started to use Notifier using VLC but I got an error.
I think is just a bug during the programming as in RM it works fine.
Let me explain with a very simple example (the real one use modes, restrictions, etc.):
I tried to use the following Notification but I got no sound:
When I checked the Log I saw this error:
dev:6092019-07-21 10:06:09.976 pm errorgroovy.lang.MissingMethodException: No signature of method: user_driver_statusbits_VLC_Thing_393.playTrack() is applicable for argument types: (java.lang.String, java.lang.Long) values: [http://192.25.25.15/Hubitat/Sounds/wav/HolaSeaUdBienvenido.wav, ...] Possible solutions: playTrack(java.lang.Object), nextTrack() (playTrack)
see it here:
So I add a new RM to debug if the problem was on the VLC or in the Notifier and with RM worked fine so it must be the Notifier. Here is my testing RM:
In HSM I'm getting the same error:
Are those bugs on the last release or I did something wrong?
