I set a switch as Intrusion Light Alerts...
Then deselect the switch from Intrusion Light Alerts list
Then arm > intrusion > disarm/cancel alerts > HSM turn the switch on/off
the switch is not In Use By HSM in device details but HSM controls the switch.
I am not able to reproduce this. First, I set up a Light Alert. Then tested by arming HSM and causing it to alert. It turned on the light as expected. Then I removed the light from HSM. Armed again, caused it to alert. The removed light did nothing in response.
As you can see Virtual Switch 1 is not in use by HSM but it turned off by HSM alert cancel/disarm.
-when I remove the switch there isnβt any switch/light left in HSM light alert.
-when I add another switch, HSM releases the previous switch and sticks to newer one even after removing it from HSM light alert.(Not all the time)
-I test with virtual and real switch/sensor.
Never mind. Now I see the problem. It's holding onto the device in the lights it captures upon alert, so that it can restore them later. I see about fixing that.
