HSM Arming Failure - how to know what type of arming mode used?
Is there a way, when HSM reports arming failed, to know what arming mode failed?
I would like to be able to arm HSM in the requested mode once the failure has been resolved. I have setup a RM that waits for the resolution on failure (waits for sensors to close) and retries arming. That works.
What I’m not able to do is know what type of arming mode I was setting, and re-use the same. Ex.: I know it failed arming, but not if it failed arming away, home or night.
Still new to this but here is a thought as I’m working through this now too.
Since I arm based on mode, I noticed that while the HSM Status won’t arm, the mode still changes. So maybe you can refer to the mode assuming it changed accordingly.
Example: Home switched to night. HSM fails but mode is now night.
Then you can use IF THEN to set differ scenarios.
I like the idea of pausing arming for X time to resolve like you mentioned. Right now I just reset my mode and prompt rearming. I only arm during the day to away and at night to a night mode or maybe away but unlikely as that starts at 12:00 am, so I generally know what mode I was in.
This is brilliant! I never thought of that. I implemented that change.
Thanks!
Im having the same issue here with trying to find the HSM Alert of "arming failure" except I cannot use the proposed solution that chrismboeke used. I am trying to have alexa say out loud "arming failure" via using a virtual contact sensor, but I cannot trigger it by using an HSM alert as there is no "arming failure" to choose. This would be a very simple rule if you have that choice under HSM alerts.
You can set up a switch to turn on under Arming Alerts in HSM:
First, go to Configure Arming/Disarming/Cancel Oprions:
Then at the bottom of that screen, go to Arming Alerts:
In that screen,you can chose a switch to turn on. This is what I have done.
I do not have that option to choose from for some reason.
I think you need to add the switch via “Lights Alerts”. Give that a try and let me know if it works.
Wow!! Genius Sebastian. Thanks so much
