Confirmed this is an issue with the cloud side of dashboard v2.0
One reload / refresh of the page, the status is correct, right? Just doesn't update with changes either in the tile itself or if the hub changes its state?
Will have a fix, but not sure when we will have this deployed. Should be soon.
Hi, for some reason I can't see the HSM tile option when trying to add a tile to my dashboard. I want this to be able to disarm and rearm if/when a leak sensor is wet. I currently have water armed through HSM. I also added an intrusion alarm too just in case it needed that too.
Ok, I figured out how to add the tile (add just the template but no device). But it doesn't show the armed status correctly. Says all disarmed when my Water Alarm is armed. Also, choosing the arm/disarm options don't seem to do anything (using a passcode).
I’m experiencing this whenever HSM state is changed my tablets that use local aren’t reflecting the change. This use to work fine but no longer working. Other status changes are showing properly whenever made but it’s only HSM not updating.
I'm having trouble with the app on phone and the tile when it pops open to give arm options. I'm unable to select anything. Except I see the hsm tile flash every time I press on the screen.
