How to use Variables for dummies
Thank you this is some good info. I'm thinking the issue is the Lock code manager, but i'm not 100% sure. I created both RM like you have listed
and
but it didn't work, the lights didn't come on even though everything showed the rules was met.
When I go into Lock code manager events, I can see where the door was locked and unlocked and once I clicked on save preference I see it's recognizing my codes are there via the events, anything I have set up for the codes isn't working, for example even my notification which worked 100% using my Kwikset lock.
Event from Alfred lock
Lock code manager shows everyone is enabled, yet there's no report logs or log settings even though I have Moderate and I tried Verbose, over the last several days of having it enabled and using the lock code, you would think there should be some reports.
The reason why I'm thinking it's the lock code manager is because even a simple notification isn't working
The notifications work if I had it set to open the front door. This worked also with my previous lock but I also wasn't using the lock code manager, I figured this was the better way to go since I have 3 locks now and I want it to know who's coming in so the greeting for that person code would trigger.
