I have a Leviton DZ6HD dimmer and I want the dimmer level LEDs to be on all the time. Although I'm using the driver for this device, this parameter is not on the config screen.
Documentation for the dimmer says the following:
LED Dim Level Indicator Timeout
So I want to send a 255 (always ON) command. I have come up with the hex string 7006FF, meaning configuration command class x70 plus parameter x06 plus xFF. But this doesn't work.
No, change the driver to Basic Z-Wave Tool. Click save then cofigure then send the command, then switch back to the leviton driver, click save then configure
I would say it is more than somewhat helpful as I posted how to use it in there with at least 1 example, and a link to all of the command classes (although I didn't check to see if the link is still working).
What kind of documentation are you expecting past "enter command class and command and params in hex"? Serious question.
I'd like to see something official written in the HE documentation. A good place to document this would be with all the other things on that page, already documented here: Device Detail | Hubitat Documentation
Not sure either of those are publicly available without login anymore. I'll try to look this weekend and verify though.
That advanced section is indeed "advanced". I'm not sure the documentation will ever say much more than to use a hex representation of the command class and command. I'm not sure a tutorial on how command classes and/or commands in a class would make much sense in the docs.
But I see your point. It would be good to have a bit more in there on that function.
Alas, now we have two community threads that someone has to first find and then read to understand how to use "Send ZWave Command". I hope someone collects the bits and puts them into the official documentation page along with the other documentation.
