How to trigger Alexa Routine from Hubitat
If you want to fire off routines, I think you should be able to make a virtual switch in HE and a routine in Alexa to launch when that switch is triggered.
If you want it to say things based on events happening you have two options to make it speak. Echo speaks requires a lot more work to setup but has a lot more features. Alexa TTS is basically just used to make it talk.
