Using Rule Machine from HTTP requests
It is also possible to cause Rule Machine to perform these same actions from an HTTP request. To accomplish this, you would create a trigger event with either "Local End Point" or "Cloud End Point." The endpoint URL given by Rule Machine has a form similar to the following:
http://192.168.0.36/apps/api/10249/trigger?access_token=ecd95469-bbcd-4889-a694-9b05ef80f4db
To run rule actions the above URL must be modified to include the list of rules and the action. The modification takes the following form:
/action=rule1&rule2&rule3
where action
is the action from the list above and rule1&rule2&rule3
are the app IDs of the rules to run, separated by ampersands.
This parameter is inserted in the endpoint URL just before the ?
that precedes the access_token
as follows.
http://192.168.0.36/apps/api/10249/trigger/stopRuleAct=943&956&10217?access_token=ecd95469-bbcd-4889-a694-9b05ef80f4db
This example would do the same thing as the code example above, where 943&956&10217
are the app IDs that were selected by consequence of the input for theseRules
, and stopRuleAct
is the action to perform.
The app IDs are the values selected by the input described above, for example, theseRules
. The app IDs can also be found for a rule by opening the rule and observing its appId in its URL as follows.
http://192.168.0.36/installedapp/configure/10249/mainPage
The app ID for that rule would be 10249.
Optionally, the value of the rule's built in %value%
variable (normally set to the value of a trigger eevent) can be specified by providing a string instead of an action name, as with myValue
in this example (note that this value must be URL-encoded and not conflict with the name of an action):
http://192.168.0.36/apps/api/10249/trigger/myValue?access_token=ecd95469-bbcd-4889-a694-9b05ef80f4db
Both HTTP GET and HTTP POST to the above endpoints are supported, with the same outcome for either.
