I pushed a PR to Ecobee Suite Manager, but want to install my fork to ensure that I didn't mess anything up. This doesn't seem straightforward (other than copy/pasting files, which is easy enough). Does anyone have instructions on how to switch a package from it's "official" repo to a fork? Unmatch -> Match just rematches to the official repo, even if I've added my fork to sources.
point the packages entry to your fork's packageManifest.json location
[In HBM] unmatch the package
[In HBM Settings] add the repositories.json raw URL as a custom repository
a. you may want to un-check the original source repo as well, so you only get one hit when matching
[In HBM] run match and select your fork
[In HBM] update packages
This seems to have done the trick for me. Happy to hear if there was a simpler way
