Hi,
I've seen a couple people ask this but they got no answer.
I know you can sort devices that are in a room on the android app.
How do you sort the actual rooms?
I'm making new rooms to organise my expanding list of devices but the new rooms are going to the bottom of the list.
I've tried a hub reboot and reinstalling the android app to try and force it to reorganise but it doesn't work. Long holding it doesn't do anything. Is there a way to do this?
I figure when you create a new room, it's assigned an "ID" and because it's new the ID would put it at the bottom of the list. Is there a way to change this ID?
Do I have to delete all my rooms and re set them back up again?
Having it so when you tap the unlock button, an up and down arrow appears on the room, would be a good addition, like how you sort the devices.
I'm guessing from the lack of replies, this is not possible.
Sorry I don't have an answer. Been seeing your post for a while and had to check what you are saying cause all mine are sorted from A-Z. Made a room called apple and sure enough it landed at the bottom.
Yeah you see what I mean then. I remember it sorting them correctly on the old Hubitat app. It's like something broke on this new app and they don't sort correctly anymore.
There is no option to rearrange or sort in any other order besides alphabetical (there never has been, AFAIK).
But I can reproduce this issue when adding a new room too, on the iOS mobile app.
I haven’t tried to create any rooms in quite some time. All the previously created rooms are in alphabetical order as expected.
But newly created rooms are added to the bottom of the rooms list in the mobile app, instead of being inserted into the expected spot in the alphabetical list of rooms.
@moncho1138
@gopher.ny
Noted for the next build. You'll need to update the hub firmware, but not the app.
FAAAAAANTASTIIC!
It's been driving me mad for the last 2 weeks. It's getting hot at home and i'm like, just scroll all the way to the bottom of 36 rooms and turn on the A/C.
I imagine it might have been broken in an update and I was starting to look into how to downgrade firmware so I could go back like 30 versions and see if it worked then, but you saved me the headache so thanks.
Look forward to the update!
EDIT: Now working as of update 2.4.3.133. Thanks very much for this guys
