I am trying to figure out how to begin setting something up to pause a rule for 5 minutes when I tap a button.
I can figure it out once I get a little push in the right direction I've seen people talking about virtual switches and etc... but with such good development... maybe there is something recent that makes this easy?
This is a rule that I set up when my cleaning lady arrives. It pauses rules for 3 hours.
also, if you create a virtual switch and set it to turn off after 5 minutes [Enable auto off} set up a rule using RM4.0:
Trigger: switch on change
if switch turns on then pause rule x
else-if switch turns off resume rule x
endif
Hell, I don't know if it's the perfect way, but my cleaning lady rule works and the switch one I've not created, but tapped it out in my head. I just did a switch for wake on lan and it works for me. Good luck. Hope my ideas are of some help to you.
One thing I don't understand is how can I trigger this rule with a button push... I don't see "button" as a possible trigger... I don't see any way to have a rule controlled by a button... I surely am missing something
Actually, rule manager has a button option. Or you can use the button controller app. I wrote a button push using rule manager for a push notification. It is built in as long as you have a button to push. My husband had surgery, so I wanted him to be able to let me know he needed me instead of trying to yell for me. The rule will configure it for you. I'll mess with it and see if i can come up with something that will fit your needs.
Ok I'm working this out in my head. Create a virtual switch that is set up to auto off after 5 minutes.
set up two rules. Rule 1:
Then rule 2 controls your actions:
If you want to cancel the resume you could put an else-if before the end-if and add the condtion of if switch is on then cancel delayed actions.
Something very important: if you set the switch to auto off after 5 minutes, you do not have to put a delay in your call to resume. If you want to be able to cancel the resume if you need it for longer, then i suggest auto off after 1 minute and delay it by 4 minutes. That way if you need it paused another 5 minutes, you just need to press the button again and it will reset for another 5 minutes. Just a thought.
Wow! Have you not updated your hub? If you haven't, you should. 4.0 has better features. 2.5 no longer exists or is being improved. I can see why these great features have been invisible to you. Shout out if you need any help.
You can do the same rule in 3.0 if you must. It's very similar. But, I didnt look for the button control in 3.0. I skipped using 3.0 and jumped from 2.5 to 4. Old dog -> new tricks. Not always good. Ha!
[EDIT] Button option is not available in 3.0 if you wanted to create it there, you would need an app like advanced button controllers. Or Button Controllers which is a built in app.
That's awesome. I see the beginning of great rule. I'm sure you'll make little changes to accommodate something that popped into your head at 3am. It's a slippery slope.
Thanks for posting this. I mimicked it to fix a presence rule that unlocked our Schlage lock twice because my wife and I ride in the same car. Her iPhone and my iPhone would trigger the presence rule at separate times. Now I have the rule delay then resume after 5 minutes.
No, you have to create a second rule to get the rule to unpause. Otherwise, you have to go into the UI to unpause it. A paused rule won't fire, so it can't unpause itself.
