Maybe Iāve missed something, but I canāt find how to execute a custom device command from RM.
Iām pretty sure that I saw and used it before but the only reference I can find is the RM documentation that refera to āexpertā section at RM main page but I canāt find it.
My understanding is that if a device includes a command in the device edit page, and has a capability that makes it available to select in RM capability listing (Refresh or Actuator are enough), then you should be able to run a command by selecting the "Set Mode, Variables or File, Run Custom Action", including the ability to pass in parameters. See screenshot below:
My problem - I realize now - is that Iām trying to run a deviceās command from a device capability (Notification) that is not exposed to RM to use to run a custom command.
Iām using the āNotify Plus Tile Driverā that exposes a command (reset) that Iād like to call. Itās a refinement that Iād like to include in my Dashboard but I can live without it - not absolutely happy, but Iāll survive!
All you need to do is include a reference in the capability list in the driver for refresh or actuator and then you can select it in RM (bit of a hack I know...)
