I am interested in getting a report of all motion detector triggers that occur overnight, I.e. midnight to 6am. I have a Hubigraph that plots this but was wondering if there is a reporting app that would list out the events so I can read it as a push notification in the morning. Anyone know of an app that does this?
Wrote this a couple years back to look to compare a set of sensors. A little rough, but it might get you close.
https://raw.githubusercontent.com/thebearmay/hubitat/main/apps/eventStateDisplay.groovy
@thebearmay thank you for sharing. I had some trouble when importing the code. I got the error:
No signature of method: Script1.definition() is applicable for argument types: (java.util.LinkedHashMap) values: [[name:Event-State Display, namespace:thebearmay, author:Jean P. May, Jr., ...]] on line 26
I noticed some other drivers, and the drivers docs page has examples where description is wrapped in metadata { ...} along with some other fields.
Do you know what the error may be related to?
Thank you for your help.
Did you try importing it as a App or as a Driver (should be as a App)
Yep. That was it. I tried to import as Driver. Worked perfectly when I did it as an App. Thank you!
