I'm wondering how I can mimic this functionality in Hubitat:
a) I can turn on/off both bedroom lights via the wall switch in the bedroom.
b) I can use the buttons on a remote in the living room to turn on/off either of the lights and I can use the remote on the nightstand in the bedroom the same way (important since I don't have an Echo in the bedroom & want to be able to turn the light on/off while I'm in bed).
c) I can tell Alexa (in the rooms where I have an Echo device), via the Wink Skill, to "Turn On/Off Closet Side", "Turn On/Off Window Side" or "Turn On/Off Bedroom". This last one turns on/off both lights. These two lights show as plugs named "Closet Side" and "Window Side" and are in a group named "Bedroom" in the Alexa app.
My current config:
I'm currently using a Wink Hub, a Quirky Power Pivot, a GE Tapt switch, two Lutron Connected Bulb Remotes and an Amazon Echo to control the two nightstand lamps in my bedroom.
The Tapt switch is in the bedroom and replaced the original outlet switch. It's in "Smart Load" mode so that power is never actually cut to the outlet & therefore to the Pivot. The top button is programmed via Wink App "Robots" to turn on both Pivot smart outlets and the bottom button to turn both of them off ('MBR On' and 'MBR Off').
The Pivot is in the bedroom and plugged into the switched outlet. The nightstand lamps are plugged into the two smart outlets on the Pivot.
The four buttons on both of the Connected Bulb Remotes (one in the living room and one in the bedroom) are configured via the Wink App to, from top to bottom, 1) Turn on Window side light, 2) Turn off Window side light, 3) Turn on Closet side light, 4) Turn off Closet side light.
Hubitat:
My understanding is that the Tapt, the Pivot and the Connected Bulb Remotes are not supported under Hubitat and that the Hubitat will ideally replace the Wink Hub. So ... what would I need in order to maintain the same functionality?
a) turn both lights on/off via wall switch,
b) turn either light on/off via remotes,
c) turn either/both lights on/off via Alexa.
Thank you!
pat----
