While trying to remove 1 device from my dashboard I accidentally filtered out all devices except the one I wanted to delete. Is there a way to recover from this without starting over?
Not that I have ever done anything similar. But if you are using legacy, the cards all stay there with a "?". If you just put all the devices you need back in (Just reselect them in the dahsboard app), then can go to each of the cards in the dashboard, click the three dots, and reselect the correct device. I don't use Easy Dashboards. So, I can't say if they work the same.
Barring anything else, could restoring a backup work?
yes, as long as there weren't other changes they wanted to keep since the backup.
