had an issue with dns and dhcp on the local network- lost my ability to connect . tried everything i knew to do including connecting directly to the lan instead of via wifi.. can't get an ip to connect to. next steps?
Did you try the hidden network reset button on the hub? Hold that for at least 7 seconds and see if connectivity returns.
That did it. I’ve had Hubitat for years and never knew of that button. Thanks for saving me!
This topic has been marked solved by the community and subsequently closed. For further discussion on this topic, feel free to create a new thread under a different category to continue the conversation.
If you are logged in, click [HERE] to get started.
