I have setup motion lights app to enable a scene on motion. Later if somebody uses the dimmer to change brightness etc, will a later trigger if the motion reset the lights back to scene? If yes, anyway to avoid override of manual changes?
Use a required expression in RM. If scene is active rule stops running
I do this for bathroom scenes I followed @bravenel 's adivice
