How to parse XML in a multipart/form-data POST? Hikvision Cams
My custom driver ([RELEASE] Hikvision Alarm (HTTP Listening/Data Streaming/Alarm Server)) waits for POSTs from Hikvision IP cameras on port 39501 and parses the XML with this code snippet:
255    def msg = parseLanMessage(description)
256    def body = new XmlSlurper().parseText(new String(msg.body))
However, it turns out some newer cameras don't send the XML in this way and I get an error:
org.xml.sax.SAXParseException: Content is not allowed in prolog. on line 256 (method parse)
Comparing the old and new cameras. I noticed the older camera sends POSTs with content-type application/xml; charset="UTF-8" and the XML is in the body of the message.
On newer cameras, it sends POSTs with content-type multipart/form-data; boundary=boundary and the XML looks like a file.
How can I handle this scenario? Thanks for any tips in the right direction.
@thebearmay - Do you have any thoughts on this, wondering if your work with files may come in handy somehow?
The resulting msg string from parseLanMessage():
[mac:4CF5DCB55351, ip:c0a801ec, port:f6d2, headers:[POST / HTTP/1.1:null, Connection:close, Host:192.168.1.218:39501, Content-Length:738, Content-Type:multipart/form-data; boundary=boundary], body:--boundary
Content-Disposition: form-data; name="MoveDetection.xml"; filename="MoveDetection.xml"
Content-Type: application/xml
Content-Length: 568
192.168.1.236
39501
HTTP
4c:f5:dc:b5:53:51
1
2023-04-07T01:46:08-07:00
1
VMD
active
Motion alarm
DS-2CD2347G2-LU(G15477384)
--boundary--
, header:POST / HTTP/1.1
Connection: close
Host: 192.168.1.218:39501
Content-Length: 738
Content-Type: multipart/form-data; boundary=boundary
Everything I need is right there. I could probably just parse the string manually...
Here's an older camera that POSTs XML directly:
[mac:64F2FBAC247B, ip:c0a801e1, port:d460, headers:[POST / HTTP/1.1:null, Connection:keep-alive, Host:192.168.1.218, Content-Length:886, Content-Type:application/xml; charset="UTF-8"], body:
192.168.1.225
39501
HTTP
64:f2:fb:ac:24:7b
1
2023-04-07T01:49:23-08:00
93362
PIR
active
PIR alarm
Bonus Room (E94085953)
DS-2CD2455FWD-IW20201104AAWRE94085953
PIR&&DS-2CD2455FWD-IW20201104AAWRE94085953,2023-04-07T01:49:23-08:00,1,1.0
Connection: keep-alive
Host: 192.168.1.218
Content-Length: 886
Content-Type: application/xml; charset="UTF-8"
, xml:192.168.1.22539501HTTP64:f2:fb:ac:24:7b12023-04-07T01:49:23-08:0093362PIRactivePIR alarmBonus Room (E94085953)DS-2CD2455FWD-IW20201104AAWRE94085953PIR&&DS-2CD2455FWD-IW20201104AAWRE94085953,2023-04-07T01:49:23-08:00,1,1.0, data:192.168.1.22539501HTTP64:f2:fb:ac:24:7b12023-04-07T01:49:23-08:0093362PIRactivePIR alarmBonus Room (E94085953)DS-2CD2455FWD-IW20201104AAWRE94085953PIR&&DS-2CD2455FWD-IW20201104AAWRE94085953,2023-04-07T01:49:23-08:00,1,1.0]
If it is coming in as form data it’s probably in a pair:value format , possibly JSON. If you temporarily remove the parser and just print the raw data what does it look like?
I've added logDebug to output description and the parseLanMessage() result:
    logDebug "Parsing '${description}'"
    logDebug "msg: '${msg}'"
This is directly copy-pasted from the Hubitat Log display in the web-based UI:
msg: '[mac:4CF5DCB55351, ip:c0a801ec, port:d0d0, headers:[POST / HTTP/1.1:null, Connection:close, Host:192.168.1.218:39501, Content-Length:738, Content-Type:multipart/form-data; boundary=boundary], body:--boundary Content-Disposition: form-data; name="MoveDetection.xml"; filename="MoveDetection.xml" Content-Type: application/xml Content-Length: 568 192.168.1.236 39501 HTTP 4c:f5:dc:b5:53:51 1 2023-04-08T16:01:07-07:00 1 VMD active Motion alarm DS-2CD2347G2-LU(G15477384) --boundary-- , header:POST / HTTP/1.1 Connection: close Host: 192.168.1.218:39501 Content-Length: 738 Content-Type: multipart/form-data; boundary=boundary ]'
Parsing 'mac:4CF5DCB55351, ip:c0a801ec, port:d0d0, headers:UE9TVCAvIEhUVFAvMS4xDQpDb25uZWN0aW9uOiBjbG9zZQ0KSG9zdDogMTkyLjE2OC4xLjIxODozOTUwMQ0KQ29udGVudC1MZW5ndGg6IDczOA0KQ29udGVudC1UeXBlOiBtdWx0aXBhcnQvZm9ybS1kYXRhOyBib3VuZGFyeT1ib3VuZGFyeQ0K, body:LS1ib3VuZGFyeQ0KQ29udGVudC1EaXNwb3NpdGlvbjogZm9ybS1kYXRhOyBuYW1lPSJNb3ZlRGV0ZWN0aW9uLnhtbCI7IGZpbGVuYW1lPSJNb3ZlRGV0ZWN0aW9uLnhtbCINCkNvbnRlbnQtVHlwZTogYXBwbGljYXRpb24veG1sDQpDb250ZW50LUxlbmd0aDogNTY4DQoNCjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04Ij8+DQo8RXZlbnROb3RpZmljYXRpb25BbGVydCB2ZXJzaW9uPSIyLjAiIHhtbG5zPSJodHRwOi8vd3d3Lmhpa3Zpc2lvbi5jb20vdmVyMjAvWE1MU2NoZW1hIj4NCjxpcEFkZHJlc3M+MTkyLjE2OC4xLjIzNjwvaXBBZGRyZXNzPg0KPHBvcnRObz4zOTUwMTwvcG9ydE5vPg0KPHByb3RvY29sPkhUVFA8L3Byb3RvY29sPg0KPG1hY0FkZHJlc3M+NGM6ZjU6ZGM6YjU6NTM6NTE8L21hY0FkZHJlc3M+DQo8Y2hhbm5lbElEPjE8L2NoYW5uZWxJRD4NCjxkYXRlVGltZT4yMDIzLTA0LTA4VDE2OjAxOjA3LTA3OjAwPC9kYXRlVGltZT4NCjxhY3RpdmVQb3N0Q291bnQ+MTwvYWN0aXZlUG9zdENvdW50Pg0KPGV2ZW50VHlwZT5WTUQ8L2V2ZW50VHlwZT4NCjxldmVudFN0YXRlPmFjdGl2ZTwvZXZlbnRTdGF0ZT4NCjxldmVudERlc2NyaXB0aW9uPk1vdGlvbiBhbGFybTwvZXZlbnREZXNjcmlwdGlvbj4NCjxjaGFubmVsTmFtZT5EUy0yQ0QyMzQ3RzItTFUoRzE1NDc3Mzg0KTwvY2hhbm5lbE5hbWU+DQo8L0V2ZW50Tm90aWZpY2F0aW9uQWxlcnQ+DQoNCi0tYm91bmRhcnktLQ0K'
I directed the cameras to POST to webhook.site. Here's what the older camera sends:
And the newer camera:
Anyone figure this out? Im trying to make a custom Hikvision listening DH and hung up on how to receive and parse out the events from the various cameras. I know there's a built in Hikvision driver but I have some different needs and that code(the parts I need) is not publicly available for me to "borrow".
No, but let me know if you ever do.
