I am building a DIY solar system including a 60 kWh battery. The battery is monitored by a Victron BMV-702. The BMV can be programmed to switch a relay at a certain state of charge (SoC). I want the Hubitat to now what the state of that relay is so I can switch things on or off. Now my question is, how do I get the state from the ralay to the Hubitat?
Is the controller activating a dry contact closure that does not have voltage? If so, then some window-door sensors can be used to sense that dry contact closure. Another option is a MIMO Lite device, which I use to detect dry contacts opening or closing, which then produces a z-wave alert. Very reliable device.
Depending on the voltage, I've also used a RIB (Relay-In-A-Box) device to detect an electric circuit opening or closing, with the RIB then turning that into a dry contact closure. I think there might be other solutions, but that's all I've personally tried. Good luck with the system!
Thanks Andy, I'll keep that as an option but since I don't have leak sensors laying around I'll give it a try with a contact sensor as @Madcodger suggests (thanks).
No the relay doesn't have voltage. It's only switching. Now I have Aqara (zigbee) and Neocoolcam (z-wave) contactsensors that I can use. Has anyone done this before?
MANY times. No voltage is perfect. The Xiaomi Aqara and Mijia contact sensors work well. Neocoolcam are garbage in my personal opinion (queue the Z-Wave fans to attack my personal opinion). Xiaomi are fine if you are careful about the repeaters you use. Not all work with them and range isn't great unless it's a Xiaomi hub you attach them to and then sync back to HE via HomeKit/Homebridge automation (this is what I do).
If there is voltage on one of these project for the contacts or power you need to monitor, you simply put a regular relay on that device you're monitoring so that the voltage turning ON at the device engages the coil of the relay, thus closing the relay's dry (no-voltage) contacts, to where you have connected the door/motion sensor (at the reed switch).
