How to integrate a Liftmaster MyQ garage door opener with Hubitat?
I found the thread below regarding integrating a MyQ enabled garage door opener with Hubitat. I'm a bit unclear, do you need an additional device in order to do this?
My Hubitat MyQ integration walkthrough - :bellhop_bell: Get Help / Devices - Hubitat
That thread is over 5 years old. You need an additional device to integrate a MyQ GDO with Hubitat in 2025, because Chamberlain has restricted access to the MyQ API.
Currently, the best way to integrate a MyQ GDO with Hubitat would be to use a RatGDO or Konnected Blaq.
Another option is Garaget paired with a relay of some sort. That's what I use, but the previously mentioned options are possibly more turnkey and self-contained.
Garadget โ€“ remotely control and monitor your existing garage door
Just to make sure we're all on the same page, what color is the Learn button on your opener?
Thanks, I think I'll skip the garage door then. I don't have a need for that much automation for a garage door. I'll stick with my remote controls.
my reply from above:
