How to Install Device Watchdog
Step 1: Go to “App Code”:
(Yours will be empty)
Step 2: Click on “New App”
Step 3: either 1. Paste the lines of code that you copied from GitHub, or 2. In GitHub, go to “Raw”, then copy the URL. In Hubitat, click on: “Import” and paste the URL in the pop-up.
Step 4: Save the code by pressing the “Save” button.
Step 5: Go back to the “App” screen and click on “Add User App”
Step 6: Select your new app from the list.
You will essentially follow the same steps (1-4) to add new drivers, then select them manually from the device screen or if you added them before adding the device, they will likely be selected automatically.
Recommendation: Start by installing Hubitat Package Manager (HPM) which will do most of this work for you for the other Apps and Drivers that have been setup to use it:
And Bundle Manager to easily install apps that were created by @bptworld:
