In an device driver, how can I get/retrieve the "Unit" value from the sendEvent command?
sendEvent(name: "temperature", value: 67.3, unit: "F")
Edit: Change question to a device driver and not an App.
device.currentState(attrName)?.unit
device.currentState(temperature)?.unit -- or -- device.currentState("temperature")?.unit
This is not working for me. Both are returning null
Do you have a valid device handle?
I think? In the original message I am sending it a "F". Is that wrong?
If you are sending an event from an app, what device are you using the store the attribute? Generally your code will look something like:
chdDevice.sendEvent(name: "temperature", value: 67.3, unit: "F")
unitValue = chdDevice.currentState("temperature")?.unit
This is for the Weather Underground device driver, not an app. Sorry.
unitValue = device.currentState("temperature")?.unit
should work if the device is querying it's own attributes. May need to give the event some time to record though. Could also try
unitValue = device.currentState("temperature",true)?.unit
to force a read from the database instead of cache.
That works. Thanks!
