How to get Nanoleaf Smart Multicolor Floor Lamp to work with Hubitat?
I just received the Nanoleaf Smart Multicolor Floor Lamp ( Nanoleaf Matter Smart Multicolor Floor Lamp )
which is pretty cool. It is a Matter device so I first had to register it with Apple Home, the use Home to put it into pairing mode, and then add to Hubitat. However, the only Nanoleaf "Type" available to choose on the Nanoleaf Device Page was "Auroua" which I chose.
However, I can't seem to control it from the Nanoleaf app, although it is completely controllable from the Apple Home App.
I've attached relevant screen shots from the two apps.
The log shows many of these:
dev:256 2025-02-10 01:00:30.975 PM stateSet error status:408
and
dev 256 2025-02-10 12:48:29.878 PM info fingerprint endpoint "01"
My question - how do I configure this device so Hubitat works as well as it does with other (including other nanoleaf) devices?
Many thanks!
![IMG_2735|230x500](upload://wy6Ct69kSxa6XBe1ljS
TfI24bUk.png)
That's not going to work -- the Aurora uses the traditional Nanoleaf LAN API, not Matter.
Try "Generic Matter RGBW Light." Run the "Configure" command after switching. Then, see if that works -- it does with the bulbs, and I imagine it would here, too.
(If it does: if you wanted to switch back to the "Device" driver, run the "Get Info" command, and share the "fingerprint" entry from Logs that this will generate there, that would also help this match up better in the future. :slight_smile: )
