Hi
New to HE
How can I delete a ZWAVE device that I no longer have access to to be able to power up and exclude
Anyway to force a delete?
Hi
New to HE
do you know what version hub you have? C7? I'm assuming since you are "new to HE" that you probably bought the most recent one. If so,
Go to settings, z-wave details, then scroll down the list looking for the device you no longer have access to. If you click refresh a few times eventually you should see a "remove" button there.
PERFECT Thank you!!
Actually solves another issue this is how you do a REPLACE also !!!
This is called a ghost. Make sure you also deleted it from your device list.
@rlithgow1 my bad I introduced two things to together.
Ghost Bad - got rid of it.
While pressing Repair until the option to remove came up I noticed another new option Replace.
ie if a zwave Thermostatic Radiator Valve died - I could 'Replace' it with a new one and all the Rules and device definitions would continue without a break or having to re-define everything from scratch again
Even if the rule breaks, you don’t have to worry, simply go into the rule and pick the new device and save. 6 and 1/2 dozen... My take anyway
Es ?
The TRVS will be in multiple Rules/Apps and Dashboards.
Can the Es take care of all of those too?
Fixed, callus’ on my fingers sometimes (well a lot mistype)
