Currently running version: 2.2.6.139
How do you edit an Action?
I can Insert an Action but no editing for me
Click on the Manage or create conditions and you can edit those actions in there. Is that what you want?
@terminal3 The conditions are fine it is the ACTIONS I am trying to access
There used to be a step after the Select Actions to Run which gave you options like...
Which is missing from the one above
Ha
I was not knowingly in the middle of an operation - so even when I closed the browser and selected to edit it returned to the mid edit point.
Exited it by adding a new action - delay 1 second and was then able to delete the Wait action.
Is that a Feature or a Bug? a very thin line separates this one.
It’s the way it is. Most of us have been bitten by this, and just accept it. Had I written the code, I would have put a Cancel button at every step. Candidly, UI design and implementation is one of Hubitat’s weak points.
part of its 'charm'
