In rules machine, the following will produce text on echo show AND it says it
in webcore i get the following
You need to set your notification device in the Webcore settings.
And then use Send Push Notification to send it as a notification to your phone.
I don't use Rule Machine, I didn't know it had access to Echo Devices directly... is that the case, or are you using Echo Speaks?
I just use Echo Speaks from Webcore or apps to send voice announcements.
I have echo speak configured..... I see the option in webcore settings ...thx.... i assume you cant change per piston
it would be really nice if webcore did the notify the same way that rules machine so you could get text and voice
thank you for the details... I figured there HAD to be a way with webcore.
YAAAY.
Tim
