How to display a multi tile from tile Builder on the standard dashboard?
Thanks so much for your reply :pray:
When you say to use a VPN, I imagine that I have to give the IP adresse of my hub ?
Otherwise how can I check of the tile is not above 1kb ?
Thank you a lot in advance
Kind regards
Yiannis
A VPN is a means by which your device (phone,tablet etc) can appear as if it is on the local network and you can get the same connectivity benefits as you can at home.
In the Tile Builder composer you will get a summary of space usage.
If you are close to 1,024 then a tile can move between being over and under depending upon the size of the content or the number of entries you are displaying. Observe the Note: at the bottom.
Try setting the oversize handling to: Cloud Endpoint and I think that will give you what you are looking for.
Thanks so much for your reply and so sorry for my late response.
I did some modifications to reduce the tile as you suggested (less than 1kb) and it works :slight_smile: thanks so much for your help!! :slight_smile:
all the best
Yiannis
