How to determine how my 3 way switches are wired?
Code in the US does not dictate wire color so your mileage will vary based on the electrician who wired the switches.
Which box are you referring to? I called out the wires above and happy to provide more detail.
I found the wiring diagrams at this site to be very helpful when I first started installing my own smart switches. I had very little background knowledge on electrical wiring.
https://www.buildmyowncabin.com/electrical/wire-3-way-switches.html
Only thing that helped me with 3 way switches was this easy to follow YouTube video: https://youtu.be/Xp4FWJRzHdo
I keep it in my “favorites” in case I ever need to reference it again.
Please email your drawing to our support together with your order number and we'll create step-by-step instructions together with visual notes as well.
zooZ support got it figured out for me. It was pretty simple actually. If you look at the diagram I drew above, I took the black wire coming from 1 and disconnected it from line and connected it to the load going into 2. Then I connected the Zen26 to line. Then I connected the white wire coming from 1 to load and the red wire to traveler. Then I connected the Zen26 to neutral.
That's pretty good support, for sure.
