Hello,
Season's Greetings! I hope you're all doing well. I would greatly appreciate it if someone could please assist me with making a web request using WebCore.
I’m able to successfully run the following command with curl:
C:\Users\dball>curl -X POST https://api.pushbullet.com/v2/pushes -H "Authorization: Bearer <hidden>" -H "Content-Type: application/json" -d "{\"type\":\"note\",\"title\":\"DND Update\",\"body\":\"DayOff=true\"}"
However, when I try to use the "Make a Web Request" action in WebCore, I encounter the following error when running the piston:
12/21/2024, 3:40:48 PM +745ms
+41ms ║http error Response Status: 400 error Message: Bad Request
Here’s the piston I’ve created:
I suspect this may be a formatting issue, but I thought WebCore would take care of it for me. If anyone has any insights into what might be causing this, I would be incredibly grateful.
Additionally, here is my setup:
FYI I have used "hidden" in place of the Key, so I may display it for review.
Thank you in advance for any help or suggestions!
