Does anyone have sample code for converting hex ipv4 address back to string?
like this? Hex to IP Converter - Convert Hexadecimal to IP - Online - Browserling Web Developer Tools
Thanks, but I'm looking for groovy code to do this.
You could try looking at some of the methods at the end of this copy of my driver...
def hex2IP(hexStr) {
ipStr=""
for(i=0;i<hexStr.size();i=i+2){
ipStr+="${hubitat.helper.HexUtils.hexStringToInt(hexStr.substring(i,i+2))}."
ipStr = ipStr.substring(0,ipStr.size()-1)
return ipStr
Thanks for this. I did figure out how to do it. Here was my solution...
public static String hex2IP(String hex)
String ip= "";
for (int j = 0; j < hex.length(); j+=2) {
String sub = hex.substring(j, j+2);
int num = Integer.parseInt(sub, 16);
ip += num+".";
ip = ip.substring(0, ip.length()-1);
return ip;
The Groovy way: ![]()
return org.codehaus.groovy.runtime.EncodingGroovyMethods.decodeHex(hex).collect{(it < 0 ? it + 256 : it)}.join('.')
Slick!
Agree, this is a really useful class that I haven't really looked at before. Thanks for the tip @Jost
