JohnRob
February 11, 2025, 1:54am
1
I thought this would be easy but I'm having trouble making this conversion.
Can you suggest where I went astray?
def testSyntax(){
def float OTf = 75.3
def String OTs = toString(OTf)
def int msgLen = OTs.length()
log.info "string length$msgLen"
String OTs = OTf.toString()
JohnRob
February 11, 2025, 2:27am
3
Thanks.
I should have seen that as the next line is correct. I just have to get used to the different structure from C (not that I'm very good at C )
Wait until you’re on your 8th or 9th language, all of the constructs start running together particularly when your bloodstream is low on caffeine.
You dont need def in front of everything, that is typically only used if you dont specify a type at all. Some people write entire apps/drivers with no variable types at all and I hate it.
This should also work to make it a string, not sure which way is better or proper.
String OTs = "${OTf}"
jtp10181:
Not sure which is more efficient but both definitely work.
system
Closed
February 11, 2026, 3:02am
7
