I am new to Hubitat and switched from Smartthings because ST does not currently allow to create rules with variables. I will need to set up a rule. While (temperature_in_attic > temperature_outside_from_internet + 5) then FAN is ON
My question is, what is the best way to set up a hardwired temperature sensor in the attic? I am using aquara with Smartthings hub, and it keeps going offline. It's hard for me to go up the attic, I need to clear out my entire closet to do it. So I want a temperature probe to go through the ceiling, and connect that probe to a device. This device can be ZigBee or Zwave or Wifi, ideally can be powered by hardwiring.
I found this thread from last year (Permanent temperature probe remote sensor - #21 by ogiewon) but I don't want this to be a project that will require me to flash some custom firmware to some development boards, come up with 3d printed custom encloses etc. Maybe there is a Zwave/wifi relay/smart outlet that I can use? For example, could I connect this device to Hubitat?
DS18B20 Waterproof Digital Temperature Sensor Stainless Steel Thermal|Temperature Instruments| - AliExpress
Or this
Tuya Wifi Smart Life Indoor Hygrometer Thermometer Brightness Detector With Fish Tank Water Temp Probe Support Alexa Google Home - Thermometer Hygrometer - AliExpress
Or this
WiFi Smart Temperature Humidity Switch Module Sensor Dual Relay Output Smart Life App Wireless Controller Work with Alexa Google|Smart Temperature Control System| - AliExpress
