I have a Shelly Wave Pro 1 connected to Hubitat that I would like to configure as follows:
The SW1 and SW2 inputs are decoupled from controlling the output relay.
The SW1 and SW2 inputs communicate their On/Off status to Hubitat.
Can this configuration change be made via the Device Preferences in Hubitat or must it be done manually using the selector button on the Shelly?
I am currently using the default "Shelly Wave Pro 1" driver. Are there other drivers available that would allow additional control of the Shelly via Hubitat?
Thanks for the reply.
I want voltage applied to SW1 and SW2 to have no effect on the output relay and I also want to be able to detect with Hubitat and Rule Machine that a voltage has been applied to either of the SW inputs.
Are you using this hardware with Hubitat? If so, with what driver? I do not see any attributes or other fields that report status of SW1 or SW2. Perhaps I don't know where to look.
Ah, I see. Looking at the Tech details for this device, I see it is more than I assumed it was, it is not just another switch. It has a crazy number of connection and use options.
Looks like even the Generic Z-Wave Plus MultiSwitch will work, but for the settings you want it would probably need to be custom made by someone to add them for your use case.
You can use the Generic Z-Wave DT Multilevel Switch driver. That will pull all possible parameters from the Shelly and allow you to set the parameters to disconnect the switch inputs from the outputs. The Shelly web site shows the parameters and values to use.
Thank you.
Unfortunately the Generic Z-Wave DT Multilevel Switch driver does not show anything in Preferences other than log settings and default current state.
I wish this device had child devices like the Zooz ZEN17 which separates the relay and sense connections into separate children.
