i can get the call to go through but i dont see a parameter to use for the notification body any suggestions.. thanks
ie https://cloud.hubitat.com/api/some appiid/41/devices/37/deviceNotification&Notification=thisthing&access_token=sometoken
goes through.. here are available options..
[{"name":"Hubitat Smart Alarm Notification Device","label":"test","type":"Hubitat Smart Alarm Notification Device","id":"37","date":"2024-01-05T19:46:48+0000","model":null,"manufacturer":null,"room":null,"capabilities":["Configuration","Notification","Switch"],"attributes":{"device":"None","dataType":"STRING","values":null,"switch":"on","status":"none"},"commands":[{"command":"configure"},{"command":"deviceNotification"},{"command":"off"},{"command":"offPhysical"},{"command":"on"},{"command":"onPhysical"}]}]
