Select Trigger Events:
Energy level of socket changed
Actions to run:
Send GET to https://mywebsite/datareceive.php?device=%device%¶meter=power&value=%value%
the device btw is an "Aeon Outlet" and the parameter used is seen as "energy : 12.345"
As you'd expect, this transfers the value of the "energy reading" as %value% upon that value changing.
However, to be more correct, i wish to transfer that "value" on a timed interval but when i set the trigger to interval i lose the ability to obtain the energy value of the device.
Q. How can i do a time-based transfer of the energy parameter value for the device?
more specifically, how do i address the energy-value as a variable such as %socket.energy% (which btw fails)
thanks anyone
thank you VERY much @FriedCheese2006
Really helpful and solves many similar tasks i had yet to find solutions for.
Took a few minutes to find all the different sections but one of the best bits of learning to date for me,
On a follow up note, it seems odd that you have to pass a parameter-value to a variable before you can make use of it.
Surely it would be more code-efficient to directly address the parameter-value?
That was my assumption of how i expected it to work up until now.
