I just setup my C5 after a period of non use. I see the app no longer easily displays the dashboard. When I try to access the dashboard, I get an HTTP error in Safari on IOS. What's the easiest way for me to setup access to my dashboard on IOS? Thanks team.
Error I get is
Safari can't open page.
The error was: "Navigation failed because the request was for an HTTP URL with HTTPS-Only enabled.
You have HTTPS only enabled on your hub. Do you want that on? If not go to Settings > Login Security > SSL > Turn off HTTPS only.
Did you update to the new 2.0 mobile app?
Did you update the hub platform?
I have the same exact issue, and HTTPS-Only is not enabled on my hub.
Using the newest available IOS app (2.1.0 - 383)
Then my next guess re-reading the error is that the Safari browser is set to HTTPS only as a security feature. Guessing there is a setting you can turn that off.
Not that I have found.
Is the Hubitat App just a shell over Safari?
Just found this topic in the Apple forums.
Not at home now, so cannot test it now.
Not the entire app, but since the dashboards are web based it would make sense that it uses Safari internally to open them.
What iOS is the device running and can you post a screenshot of the error so we can see the exact context?
I assume you are going in the mobile app > Dashboards Tab > Select a dashboard?
Regular Dashboard or EZ Dash?
