Here are the logs after the power cycle.
Logs after power
dev:152022-08-14 10:29:31.414 pm info reporting configuration for Power Configuration (cluster 0x0001), attribute 0x0021 failed, unsupported attribute
dev:152022-08-14 10:29:31.411 pm debug descMap:[raw:catchall: 0104 0001 01 01 0040 00 FC7C 00 00 0000 07 01 86002100, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 21, 00]]
dev:152022-08-14 10:29:30.615 pm info skipped:[raw:catchall: 0000 8021 00 00 0040 00 FC7C 00 00 0000 00 00 688D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[68, 8D]]
dev:152022-08-14 10:29:30.613 pm debug descMap:[raw:catchall: 0000 8021 00 00 0040 00 FC7C 00 00 0000 00 00 688D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[68, 8D]]
dev:152022-08-14 10:29:29.809 pm info reporting configuration for Temperature Measurement (cluster 0x0402), attribute 0x0000 failed, unsupported attribute
dev:152022-08-14 10:29:29.805 pm debug descMap:[raw:catchall: 0104 0402 01 01 0040 00 FC7C 00 00 0000 07 01 86000000, profileId:0104, clusterId:0402, clusterInt:1026, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:152022-08-14 10:29:29.004 pm info skipped:[raw:catchall: 0000 8021 00 00 0040 00 FC7C 00 00 0000 00 00 668D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[66, 8D]]
dev:152022-08-14 10:29:29.001 pm debug descMap:[raw:catchall: 0000 8021 00 00 0040 00 FC7C 00 00 0000 00 00 668D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[66, 8D]]
dev:152022-08-14 10:29:28.203 pm info reporting configuration for Illuminance Measurement (cluster 0x0400), attribute 0x0000 failed, unsupported attribute
dev:152022-08-14 10:29:28.200 pm debug descMap:[raw:catchall: 0104 0400 01 01 0040 00 FC7C 00 00 0000 07 01 86000000, profileId:0104, clusterId:0400, clusterInt:1024, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:152022-08-14 10:29:27.398 pm info skipped:[raw:catchall: 0000 8021 00 00 0040 00 FC7C 00 00 0000 00 00 648D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[64, 8D]]
dev:152022-08-14 10:29:27.395 pm debug descMap:[raw:catchall: 0000 8021 00 00 0040 00 FC7C 00 00 0000 00 00 648D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[64, 8D]]
dev:152022-08-14 10:29:26.592 pm debug skipped:[raw:catchall: 0104 0406 01 01 0040 00 FC7C 00 01 100B 01 01 300086, profileId:0104, clusterId:0406, clusterInt:1030, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:100B, command:01, direction:01, data:[30, 00, 86]]
dev:152022-08-14 10:29:26.589 pm debug descMap:[raw:catchall: 0104 0406 01 01 0040 00 FC7C 00 01 100B 01 01 300086, profileId:0104, clusterId:0406, clusterInt:1030, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:100B, command:01, direction:01, data:[30, 00, 86]]
dev:152022-08-14 10:29:26.359 pm info Master bathroom occupancy is active
dev:152022-08-14 10:29:26.357 pm debug descMap:[raw:FC7C0104060800001801, dni:FC7C, endpoint:01, cluster:0406, size:08, attrId:0000, encoding:18, command:0A, value:01, clusterInt:1030, attrInt:0]
dev:152022-08-14 10:29:25.784 pm debug descMap:[raw:catchall: 0104 0406 01 01 0040 00 FC7C 00 01 100B 04 01 863000, profileId:0104, clusterId:0406, clusterInt:1030, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:100B, command:04, direction:01, data:[86, 30, 00]]
dev:152022-08-14 10:29:24.992 pm info reporting configuration for Occupancy Sensing (cluster 0x0406) succeeded
dev:152022-08-14 10:29:24.981 pm debug descMap:[raw:catchall: 0104 0406 01 01 0040 00 FC7C 00 00 0000 07 01 00, profileId:0104, clusterId:0406, clusterInt:1030, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:152022-08-14 10:29:24.167 pm info skipped:[raw:catchall: 0000 8021 00 00 0040 00 FC7C 00 00 0000 00 00 6000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[60, 00]]
dev:152022-08-14 10:29:24.164 pm debug descMap:[raw:catchall: 0000 8021 00 00 0040 00 FC7C 00 00 0000 00 00 6000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[60, 00]]
dev:152022-08-14 10:29:23.360 pm debug skipped:[raw:catchall: 0104 0406 01 01 0040 00 FC7C 00 00 0000 01 01 100086, profileId:0104, clusterId:0406, clusterInt:1030, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[10, 00, 86]]
dev:152022-08-14 10:29:23.356 pm debug descMap:[raw:catchall: 0104 0406 01 01 0040 00 FC7C 00 00 0000 01 01 100086, profileId:0104, clusterId:0406, clusterInt:1030, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[10, 00, 86]]
dev:152022-08-14 10:29:22.557 pm debug descMap:[raw:catchall: 0104 0406 01 01 0040 00 FC7C 00 00 0000 04 01 861000, profileId:0104, clusterId:0406, clusterInt:1030, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FC7C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, 10, 00]]
dev:152022-08-14 10:29:22.394 pm warn description logging is: true
dev:152022-08-14 10:29:22.393 pm warn debug logging is: true
dev:152022-08-14 10:29:22.392 pm info updated...
