I am trying to set up a whole house attic fan Rule. I need it to turn on at sunset and if the Master Bedroom temp is > then the outdoor temp, It looks like the triggers default to OR I Need both triggers to be true.
Or do I need multiple separate rules?
One to turn it on at sunset.
Another to turn it off if the Master Bedroom temp is < then outdoor temp
And then one more to turn it on at sunrise for a early morning cool down?
There may be a more elegant way of doing this, but what I do is 2 seperate rules.
Rule 1, trigger=sunset, but add a condition that says if bedroom temp is <
Rule 2, trigger=Bedroom temp >, and a condition that says between sunset and sunrise
Trigger: Sunset or Sunrise
Condition: Bedroom Temp > Outdoor Temp
Action: Turn on Fan
OK so not multiple triggers. Thanks
I would go with one rule:
trigger = sunset
If bedroom temp > outdoor then
turn on vent
wait for condition bedroom temp < outdoor temp or sunrise
(or whatever time you want it to stop checking)
Turn off vent
END IF
Triggers cannot ever be AND because they are events and both won't happen at the exact same instant in time. You can use OR with multiple triggers and then use a Conditional for other device for it's state. This gets a lot of people.
OK Thanks to all for the advice.
I have the following which should work. I want the fan to cycle on and off. So that the upper floor stays as cool as possible, then shut off at a fixed time. I have a similar rule for sunrise to do a morning cool down. The basement temp probe is moved out to the front porch for the summer.
