I have a rule that notifies me of monthly energy use.
I had to set a variable, "energy", and use that in the notification as %energy%.
If it would've been something else, that the Notifications app covers, it would've been possible, and I could've used %text%.
If I try this without going the variable approach, all I get are "nulls".
How does one use %text%, %device%, %value%, etc, in Rule Machine?
Those values come from the trigger event.
Thanks. I'll give it a whirl.
I can't figure out how to do a periodic notification for 12AM on the first day of the month.
I can get %value% to work if I put it in Trigger, but nothing is available to get the periodic notify.
Can't do two triggers, because it's OR.
Can't use a required expression for the period, because that choice is not available.
I must be missing something.
You do this, instead of using the Energy as the trigger:
To get the energy level, you pull it into a variable, and notify with the variable.
system
Closed
7
