How do I issue a +1 or -1 set point change to a thermostat in rules
I am probably overlooking something but how do I have a rule execute a +1 or -1 of a set point?
Use case is from a custom dashboard (using Sharptools) I want to but buttons to change set points that calls a rule that lowers or raises the setpoint.
Thanks.
There is an action in Rule Machine to adjust a setpoint +/- by an amount you pick. So all you need is that action:
