New to this whole thing..... I currently have two fibaro dimmer 2 switches in stalled in my bedroom and I am wanting to utilise the S2 switch to control individual lights and the other dimmer.
The main switch in the room I'm planning on having 4 zigbee downlights connected to the S1 switch. S1 will control basic on off function but I would like to have the S2 switch power off to two of the 4 lights on one press, then one more of the 4 lights on another press and on the third and final press switch off all 4 lights plus the closet light (separate circuit with dimmer 2 also).
I have the Eric drivers installed but I have no idea how to use them to control this feature. Please help.....
Did you get this working I've only just done mine.
If you press the switch connected to s2 then look in the switch logs it should show up which button to use then you can download button controller app and go from there.
I get nothin. I don't really understand the last few settings in the driver. Also it refers to scenes which I know is what the buttons were intended for. I have mucked around with button controller and activating/deactivating those last few scene settings in the driver but after trying to config the button controller I get nothing...
Got it working! I used the ecrom driver. Turns out I had to do a forced calibration after activating scenes. Set up button in button controller. Gave the hub a restart and BANG!
I confirm the forced calibration (shut off the power) fixed the issue for me too. Using the erocm driver. I have one other dimmer that doesn't like the erocm driver, I had to exclude and re-pair and stay with the hubitat default driver. The lights briefly light up then turn off. @bigsaucyorse Thanks for the hint on the calibration/power cycle !
